openatv-7.5-formuler4turbo-20240921
Openbox formuler4/Formuler F4 TURBO
OpenPLi 9.1 » Stable release
Formuler F4 Turbo-20241226_
New or improved Plugins and Settings:
[AutoDiseqc] update frequency 36E
Sabctools: Downgrade to 7.1.2 (Sabnzbd 4.1.0 and older doesn't work with sabctools 8.0.0. Awaiting stable 4.2.0 release Sabnzbd which can)
Sabnzbd: Update to version 4.1.0
Sabnzbd: Fix SABnzbd file extension
Add plugin Free channels, Plugin to scan bouquets to find FTA (free-to-air) channels and add to the bouquet if it contains the specified language.
Sabnzbd: Update to version 4.2.1
Disable clockfix option in oscam, the timesettings are done by NTP
Openvpn add openresolv update script for DNS updates
Added Czech meteo viewer plugin
Added enigma2-plugin-extensions-xklass streaming plugin
Update enigma2-plugin-extensions-epgimport-rytec
Add whitelist for OSCam icam channels
Wireguard lower the minimum kernel requirement to 3.10
Add OSCam streamrelay whitelist
In PluginDownloadBrowser add expand/compress for green button
Add enigma2-plugin-extensions-jediepgxtream to the feed
