Ncam 14.9 compiled and patched by marouan & RAED
NCAM 14-9 for ARM64- ARM – MIPS CPU
Ncam
Ncam
Ncam V15.0
- omnicrypt: Add ecm support.
- Update reader-videoguard-common. this change has been in the forrums for a few years but not yet implemented thanks to (Didov3).
- revert to discarded parts, as they are also an important part of the module-serial.
- fix openssl dependency.
- added Fransat V6 cards to hanlde ECM of UHD Channels thanks to Constance and rumas84.
- add Dreambox Reader detection
- Dgcrypt 0x4AB0 with EMM * adding EMM Support for DGCRYPT 0x4AB0 thanks to lnj * adding support for non-standard ISO 7816-3 protocol for pcsc module thanks to lnj
- add hide Provid-SA IRDID
- Fix 'can't find 0xf0 in emm...' on Fransat V7 card (Thanks to nitida and OptimumPower)
